Activity Forums Apple Final Cut Pro Legacy transitions cause video to shift
  • transitions cause video to shift
    Posted by James Crosbie on June 25, 2009 at 9:55 pm
    I can’t figure out why, when I add a transition to a graphic or video, such as a glow dissolve, my video shifts on the first frame of the transition and on the last frame of the transition. It seems to only happen when I am working in SD format and not in the HD format. I thought that it may be a field order problem, however, the field dominance in my sequence settings is set to LOWER, which to my understanding is the right field for NTSC-CCIR 601/DV Aspect Ratio. Any thoughts?
    James Crosbie replied 17 years, 2 months ago 3 Members · 3 Replies
  • John Fishback
    June 25, 2009 at 10:17 pm
    Try force rendering the transition. I’ve seen this a couple of times. I never figured out why it was happening. There was no render line showing, but if I did a render-only > full, it transitioned properly.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Shane Ross
    Everything fully rendered?
    Shane
  • James Crosbie
    June 26, 2009 at 3:29 pm
    Everything is rendered and I did try the render> only full option, that John suggested and the video still shifts. I have notice that the video does not shift on simple dissolves and a fades. Could it be a glitch in my effects packages from NI and Volumertx?
