Activity Forums Apple Final Cut Pro Legacy transitions are “more green” (colour shift) in FCP
  • transitions are “more green” (colour shift) in FCP
    Posted by Mike Barber on December 8, 2008 at 8:01 pm
    I am noticing a slight colour shift in FCP during an edge wipe transition. The rendered frames during the transition are noticeably greener — especially obvious in green elements in the shot 9they become a slightly lighter/brighter shade of green). I see it in the Canvas, the broadcast monitor and the (external) scope.
    The clips are uncompressed 8-bit 4:2:2 as is the sequence. Video processing is set to 8-bit YUV. Render control is set to “Same as Sequence Codec”. Using FCP 6.0 on PowerMac G5 with Kona 2.
    Any ideas?
    I have tried using other transitions (edge wipe, cross-dissolve, non-additive dissolve, etc) and it happens on all of them. Very odd.
    Mike Barber replied 17 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
