Activity Forums Apple Final Cut Pro Legacy Transitions and Outer Glow Filter
  • Transitions and Outer Glow Filter
    Posted by Emilio Martinez on April 25, 2008 at 1:01 am
    Whenever I use the Outer Glow filter on a clip, the characteristic of the glow changes to any portion that has also has a transition on it.
    Has anyone else experienced this, and if so, do you have a fix?
    Rafael Amador replied 18 years, 5 months ago 3 Members · 5 Replies
  • Rafael Amador
    April 25, 2008 at 2:10 am
    Try nesting the clips with the transition before applying the Glow filter.
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • Kevin Monahan
    April 26, 2008 at 5:03 pm
    By nesting, you are reversing the order of the render pipeline. That’s why it works that way. I wrote a little chunk about this in my book.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Rafael Amador
    April 27, 2008 at 3:34 am
    Right Kevin. I’ve to give it a read again.
    JVC DTV-17″
  • Kevin Monahan
    April 27, 2008 at 5:13 pm
    Yep. Page 297 where I describe how to do this via nesting. You have to do the same thing in After Effects and Motion as well.
    The render order of effects in FCP is:
    1. Speed
    2. Filters
    3. Motion Effects
    4. Motion Blur
    5. Opacity
    6. Transitions
    If you have an effect that is not having the right appearance, likely you have to trick the render order via nesting.
    I wrote MGEFCP to have staying power with techniques drawn from FCP’s core. It is still very relevant to FCP 6–the project file is working fine and all the info is still current.
    I think it’s a good primer to fx in general and would be very helpful to editors that want to live within the app more often, rather than having to jump to Motion all the time.
    Kevin Monahan
  • Rafael Amador
    April 28, 2008 at 11:59 am
    Is the book i’ll recommend to anybody that wants to get in with FC fast and efficiently.
    No unnecessary paper waisted.
    Also is a book to have always near by when you start to grow old and forget the basic of your daily application:-)
    I’ll pick it again
    JVC DTV-17″
