Activity › Forums › Apple Final Cut Pro Legacy › Transitions and Green Screen
  • Transitions and Green Screen
    Posted by Nick Nichols on January 21, 2009 at 8:01 pm
    I’m trying to add a transition(Split slide) between two clips on the same track. The first clip is not using a green screen. The second is. All is good with those until I add a transition. Then it plays the first clip normally until the transition at which time it shows the second clip with a black background and green lines around the people. I’ve tried adding a drop shadow as one forum suggested, but that didn’t work. I’m using FC Pro 5.1.4. Thanks!
    Jason Diebler replied 17 years, 6 months ago 3 Members · 2 Replies
  • Dennis Leppell
    January 21, 2009 at 9:12 pm
    export the green screen clip as a reference file with some handles, them reimport and use that as your footage on the timeline.
    I suppose in theory that this could also be done by nesting the greenscreen clips, but I’ve never tried it.
  • Jason Diebler
    March 18, 2009 at 8:01 pm
    Late response to this thread, but I came across the topic… and yes, it works to nest the clip, no need to export or anything like that.
