Activity › Forums › Adobe After Effects › TRANSITIONS
TRANSITIONS
Posted by Edbrooklyn on April 10, 2006 at 11:57 pmHow do I apply transitions in AE 6.0 Does anyone knows of a step by step tutorial?
Thank You!!!
Eduardo Hernandez
Edbrooklyn replied 20 years, 4 months ago 2 Members · 4 Replies -
Ryan Hill
April 12, 2006 at 7:42 pmPut the layer you are starting with on top. Put the layer you are ending with below it. Apply the transition filter to the top layer.
Edbrooklyn
April 13, 2006 at 1:44 amThank you for you response,
I tried what you told me but it still not happening, I still don’t get the transition to appear. This is what I am doing, (I am new at After Effects, just picked it up a month ago)
1. I make a new composition
2. I import 2 files (just stills fot now)
3. I drag file no. 1 to the timeline
4. I drag file no. 2 to the timeline
5. Then I go to the effects windows and choose transitions/Linear wipe and drag it to the top layer as you said
6. Then I shorten the top layer to about 10 seconds
7. I start second layer write after the 10 seconds clip
8. I preview to Ram but no transition showing upAm I missing a step?, do I have to keyframe it? why is not as simple as drag and drop and that’s it?
Thank you for your patience
Ryan Hill
April 13, 2006 at 5:32 pmOh, right. I forgot. You need to animate the transition.
There will be a property in the transition effect that is set to 0%. Set a keyframe where you want it to start, go to where you want it to finish, and change it to 100%.
If you just want to drag and drop, there’s other programs that are more geared towards that sort of thing. I’ve used iMovie and that’s basically what that’s like, but then I was frustrated that I couldn’t do anything more complex. Premier is more powerful, but also more complicated than iMovie. It’s a trade-off. After Effects leans towards the complex but powerful side of the spectrum.
Edbrooklyn
April 13, 2006 at 11:32 pmThank You so much RobotHero!!!! I did what you told me and it worked perfectly!!! I went to the “Transition Completion” keyframed it from 0 to 100 and it worked. Thank you so much,
Eduardo
