Activity › Forums › Apple Final Cut Pro Legacy › Transition woes
  • Transition woes
    Posted by Laurie Patton on September 1, 2011 at 9:22 pm
    I have a very simple lower third with a solid back at about 40 opacity.
    At first when I tried both cross dissolve or fade in fade out first the words would come up and then the bar would pop in. I solved that problem through trial and error.
    But, now the front fade in is just too fast. More of a pop in than a fade in. Fade out is just fine.
    I’ve tried extending the time and that doesn’t work. Any help would be super appreciated.
    Thank you! Laurie
    Miriam Lefkowitz replied 15 years, 1 month ago 3 Members · 2 Replies
  • Jeff Greenberg
    September 3, 2011 at 2:51 am
    How about nesting the lower third and solid back into it’s own sequence (opt-c) then fading that up/down?
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Miriam Lefkowitz
    September 3, 2011 at 3:36 pm
    When I can’t get the transitions to work the way I want I’ll use the pen tool instead and work directly on the video overlay line in the timeline, using keyframes to fade the clips in and out, not the cross-dissolve filter.
