Activity › Forums › VEGAS Pro › Transition Shortcut (Vegas 13)
  • Transition Shortcut (Vegas 13)
    Posted by Joseph Abaji on October 29, 2016 at 2:03 am
    Right clicking a cross fade in timeline > transition opens a menu with possibilities of adding a “crossfade” with the num / on keyboard and also adding “most used” transitions. When I was using Vegas 11, I used to have my num / key add a specific transition (example: Vegas Flash) when my cursor was on a crossfade. Is it possible to have my num / key add a specific transition instead of just “crossfade” while putting my cursor on a crossfade (as I had it in Vegas 11). I’m currently using Vegas 13.
    Thank you
    Roger Bansemer replied 9 years, 11 months ago 3 Members · 2 Replies
  • Graham Bernard
    October 29, 2016 at 5:48 am
    I’m assuming you tried it and it doesn’t work? If you did, had you got NumLock “ON”, on the keypad?
    * Grazie
  • Roger Bansemer
    October 29, 2016 at 10:42 am
    If you hold down the shift key when dragging a transition to your events, it will eliminate the fine tuning choices and simply drop the default transition on there. That saves time.
    Roger
    Roger Bansemer – PaintingAndTravel.com
