Activity › Forums › Adobe Premiere Pro › Transition results in bad pixelation
  • Transition results in bad pixelation
    Posted by Nicki Dreyer on December 3, 2014 at 10:22 am
    Hi guys! I hope you can help me!
    We have just switched from FCP to Premiere, producing promos. We use a lot of push slides, however, I’m experiencing problems with this.
    I can apply the effect and it looks OK, but once I render it, the quality on the transition gets very very bad, highly pixelated.
    I have tried to play with the Anti-Alias quality, which works sometimes – but again, only until I render it.
    Is there something I’m missing or how can I make sure it looks good? It cannot be aired like this …
    See image attached
    Oh – the sequence settings we’re using are Sony XDCAM HD1080p, Square pixels, Upper field – the same settings we have used for years in FCP with no problem.
    Has somebody here experienced this issue?
    To be safe, we also tried this on another machine with different footage – the result / problem is the same.
    Joe Barta iv replied 11 years, 10 months ago 2 Members · 1 Reply
  • Joe Barta iv
    December 3, 2014 at 4:34 pm
    What is your Preview File Format set to?
    Under Sequence Settings / Video Previews / Preview File Format. Sometimes the MPEG rendered previews fall apart. Try changing them to Quicktime or something else.
    Living the SuiteLife!
    Stuff for editors http://www.cafepress.com/suitelife
