Activity Forums Apple Final Cut Pro Legacy Transition question
  • Transition question
    Posted by Bryce Douglass on October 21, 2010 at 10:12 pm
    Hello, I have used Final Cut Pro for about a year and for some reason I’m having an issue with the transitions. Every time I go to add a fade or cross dissolve etc it brightens the image and then does the transition. It’s a white flash while played in real time. I exported the video thinking maybe this was some rendering issue and it is there in the exported file. Does anyone know how to go about fixing this? I’ve never encountered the problem before.
    thanks.
    Bryce
    Tony Brittan replied 15 years, 11 months ago 2 Members · 7 Replies
  • 7 Replies
  • Tony Brittan
    October 21, 2010 at 10:18 pm
    What codec is the footage? I’m guessing something like h.264 or another compressed codec. If so, transcode to prores or other edit friendly codec before attempting to edit.
    Tony Brittan
    Apple Certified Pro – FCP
    Owner – Island Shore Productions
  • Bryce Douglass
    October 21, 2010 at 10:22 pm
    I have exported the footage to xdcam 720p. Now that I think about it it has been happening with footage from my newer camera that I just bought which shoots on memory cards. I can’t import the file from the memory card into final cut so maybe when I export it something weird happens.
    Bryce
  • Tony Brittan
    October 22, 2010 at 5:23 am
    Pretty much anything that comes from a memory card or other digital form must be transcoded for FCP unless it’s one of the couple that it supports natively (like Sony XDCAM). If you’re not using Log & Transfer, try transcoding in compressor or MPEG Streamclip.
    Tony Brittan
  • Bryce Douglass
    October 22, 2010 at 5:38 am
    I do use mpeg stream clip but it still happens.
    Bryce
  • Tony Brittan
    October 22, 2010 at 5:53 am
    Try using Prores (non HQ).
    Tony Brittan
  • Bryce Douglass
    October 22, 2010 at 6:21 am
    non hq as in not HD? Sorry I’m not to familiar with codecs.
    Bryce
  • Tony Brittan
    October 23, 2010 at 11:35 am
    Well, depending on what version of FCP you’re using, you have options for what Prores you can use. In FCP 6 it’s either regular Prores and the HQ version. HQ is overkill, intended for RED or better footage (over 2k), and can cause problems that you can read about if you’d a search. Anyway, in FCP 7 there’re more choices as well. But you can’t go wrong with standard Prores! The HQ doesn’t mean HD…Prores will work with whatever resolution (720p, 1080i60, NTSC) you are working with and is almost always your best choice when using FCP. Hope that helps!
    Tony Brittan
