Activity › Forums › Apple Final Cut Pro Legacy › Transition Question
  • Transition Question
    Posted by Paul Jones on September 27, 2005 at 1:56 pm
    Hi There
    I am putting a venetian blind wipe effect between 2 shots and I have a problem.
    Currently you can set the wipe to go left to right/right to left by setting angle to 90 degrees or 270 degres etc but I need both sides to wipe in.
    Any suggestions appreciated
    Jim Kanter replied 21 years ago 3 Members · 2 Replies
  • Jerry Hofmann
    September 27, 2005 at 2:35 pm
    Probably should look for a plugin transition for this… FCP won’t do it anyway very easily… but if you were to export a version going r to l then another version going l to right, you could import those self contained QT movies and do a simple vertical wipe between them or crop one side to reveal the side that wipes in the other direction.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jim Kanter
    September 27, 2005 at 10:10 pm
    1. Split both A and B clips close to the transition that covers them (and outside the transition edges).
    2. Make a second copy of the two clips and the transition on the track directly above.
    3. Open the transition above and click on the reverse direction button.
    4. Select the transition and clips and nest them into a new sequence.
    5. Horizontally crop the new clip (above) 50%.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
