Activity Forums Adobe Premiere Pro Transition Question
  • Transition Question
    Posted by Aaron Cadieux on March 21, 2008 at 3:35 pm
    I’ve been cutting on PP for years, and it just occured to me to ask this. Is there a way to select a whole string of clips on the timeline and tell premiere to put the same transition at the same frame length between each shot rather than having to place the transitions in one by one? There are some instances where that would save me oodles of time.
    -Aaron
    Eric Jurgenson replied 18 years, 5 months ago 2 Members · 1 Reply
  • Eric Jurgenson
    March 21, 2008 at 4:03 pm
    You could create a keyframed dissolve with the opacity filter, then copy and paste attributes to a series of selected clips; but it would probably be easier to use the page down key to sequence through the clips, and ctrl-d (ctrl-shift-d for audio crossfade)to add the dissolve (default transition). This goes very quickly – about one dissolve per second.
