Activity Forums Apple Final Cut Pro Transition Problems
  • Transition Problems
    Posted by Chillaa Soseriuz on February 8, 2012 at 12:06 am
    When ever i have a clip layered over another clip it deletes both clips when i try to delete the bottom one -_- … you’ll understand what I’m saying when you look at the pictures!
    Tom Wolsky replied 14 years, 7 months ago 2 Members · 7 Replies
  • 7 Replies
  • Tom Wolsky
    February 8, 2012 at 12:31 am
    Press Shift-delete to replace the clip with a gap clip.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2012 “Complete Training for FCPX” from Class on Demand
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
  • Chillaa Soseriuz
    February 8, 2012 at 12:36 am
    Thanks for you response , I did that but after i deleted the clip and tried to drag the other clip down to that position all of the clips shifted :/
  • Tom Wolsky
    February 8, 2012 at 12:46 am
    If you need to drag it use the Position tool. Or use Opt-Cmd-down arrow to Overwrite to Primary Storyline.
    All the best,
    Tom
  • Chillaa Soseriuz
    February 8, 2012 at 12:49 am
    It works!
    I appreciate all of the help it was much need!
    Thank you
  • Tom Wolsky
    February 8, 2012 at 1:05 am
    You could have skipped the first step. Just Opt-Cmd-down arrow would have overwritten the clip that was on the primary storyline. The audio would have been pushed down as a connected clip, but all you would have to do is select it and delete it.
    All the best,
    Tom
  • Chillaa Soseriuz
    February 8, 2012 at 1:06 am
    Very last question . I hope !
    When ever i drag a transition to put between two clips it shifts all of the other clips how can i avoid that?
  • Tom Wolsky
    February 8, 2012 at 7:17 am
    Make sure you have enough handles to create the transition overlap before you edit the clip into the timeline. If you don’t the application will have to trim the clips to make the overlap.
    I would suggest you spend some time learning the basic of editing and the application.
    All the best,
    Tom
