Activity Forums VEGAS Pro Transition Problem Vegas 9?
  • Transition Problem Vegas 9?
    Posted by Mike Carlo on December 21, 2009 at 11:09 pm
    I am using a Toshiba A505-6975 to edit. I captured in SD mode from a Canon HV 20 CC. When I put a cross fade between two clips (both SD) the preview comes up to the cross fade I get like a flashing effect. I even tried draft auto preview still flashing. I tried rendering out to a mpeg2 file and the flashing is still there. At first I thought it was that the video clip was corrupted but when I separate them and play them back they play fine.
    I used 9.0 b, and 9.0 c both exhibit the same problem. Not all clips will do it. If I take the cross fade away and just do a straight cut the clips play fine. I even tried to change the transition to no avail. Has anybody else seen this?
    Thanks, Mike
    August Spencer replied 16 years, 8 months ago 3 Members · 2 Replies
  • Jeremy Rasnic
    December 22, 2009 at 5:08 pm
    If you have tried to change the transition to another transition and still get this, it sounds like something is wrong.
    However, post a screen grab of the preview window showing this anomaly as well as a screen grab of your crossfade on the timeline.
    And for the sake of double checking, add a completely different transition, such as barn doors or something that is obviously not a crossfade and see if you get the same flash.
    j razz
    https://www.jrazzcreations.com
  • August Spencer
    January 21, 2010 at 6:50 pm
    I am having a similar problem with some fade-ins. That is, when I use several starting screens, packaged with Vegas 9, and I apply a fade-in to them by varying the compositing level from 0 to 100%, they flash instead of varying gradually from black to full picture.
    I should clarify that this problem does not occur in High Definition either in preview or final BD from DA5.
    However, when I move the rendered (high definition) file to DA5 to make a standard DVD (SD), both the preview and the final SD DVD show the flashing fade-ins.
    I noticed that the flashing does not occur on solid colors, or black, but only on some pictures with gradient colors, specially from white.
    This problem does not occur either if I apply fade-in to a video scene directly.
    The obvious workaround is to avoid those starting screens with gradients or other trouble content. But, I would like to use all of the supplied screens when apropiate …
    Has anyone found the actual fix ?
