Activity Forums Boris FX Sapphire transition problem
  • transition problem
    Posted by Paul Thomsen on September 27, 2010 at 3:55 am
    Gday just trying this out and having issues doing transitions in Premiere CS5. Worked out how to keyframe the transition on different video tracks after initial confusion after I realised it doesn’t work as normal transitions.. but… if the transition is going to a clip with another effect on it – such as mercalli stabiliser… i notice that the transition uses the original source of the clip (eg non stabilized) for itself which produces a jump to the modified clip footage when the transition is over…
    Paul Thomsen replied 15 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
