Activity › Forums › RE:Vision Effects › Transition issue with Twixtor (demo)
  • Transition issue with Twixtor (demo)
    Posted by John Mark on September 15, 2013 at 10:18 am
    Hello, I recently downloaded the demo for Twixtor, and thought I try converting a simple SD video from 25fps to 50fps. It has worked great, just the only issue is, the transitions are a-little “wiggly” on a single frame on cut.
    Have a look – https://f1.creativecow.net/6513/6513?private=1
    Is there a fix to this?
    Thank you.
    A News Graphic Lover
    John Mark replied 13 years ago 2 Members · 4 Replies
  • Pierre Jasmin
    September 15, 2013 at 5:40 pm
    Did you play with the Mark Scene Cut menu?
    See tutorial:
    https://help.revisionfx.com/album/18/#/tutorial-35
  • John Mark
    September 16, 2013 at 2:23 am
    Thank you for the reply, the tutorial helped alot. Just one question, does this mean I have to edit every singly cut and fade transition? My clips are 50min long.
    Thank you.
  • Pierre Jasmin
    September 16, 2013 at 7:13 pm
    It could mean that
    I am not sure if you have the original edit, it’s sometimes possible to load edit project in Premiere (if it’s not edited in Premiere, for example Premiere can load FCP 7…), import Premiere Project in AE. Then each clip will be on a different layer. If you are only doing frame rate conversion, you can probably set one Twixtor setup, copy it, select all (all layers) and paste Twixtor to all layers.
    Pierre
  • John Mark
    September 25, 2013 at 12:48 pm
    The video clips are from Youtube, running at 25fps (PAL). Im just trying to get them converted to 50fps.
