Activity Forums Adobe After Effects Transition effects tutorial – can’t find
  • Transition effects tutorial – can’t find
    Posted by Elisabeth Juusu on May 19, 2019 at 8:57 am
    Can somebody help me to find a tutorial how to make a transition I saw from That 70s show tv-show? Can’t seem to find how to make mask for this or how to not manually do every single circle.
    Video:
    https://youtu.be/jxvjTCDPUPo
    Would really appreciate the help!
    Greg Gesch replied 7 years, 4 months ago 2 Members · 1 Reply
  • Greg Gesch
    May 20, 2019 at 1:20 am
    Hi Elisabeth. A way to do it:
    Make a new square composition (say 250×250). Double click the Ellipse Tool to create a circle – fill white, stroke pink. Keyframe the Elipse 1/Transform/Scale from 0 to say150 – so that the circle appears, grows and the composition ends up totally white.
    Duplicate the square composition IN THE PROJECT PANEL and open this version of the square composition. Make the fill an alpha, so you have only the pink stroke.
    In your main composition have the video you transition to above the video you transition from.
    Add the white circle comp above the beginning of the transition. Go to the time when the circle just fills the square shape and then scale the circle comp so that the circle is the size you want them all to be.
    Add the CC Repitile effect to the white circle comp and expand the up/down etc headings so that the screen is filled with the circles. (You may need to play with the scale of the comp to get even rows.)
    Set the TrkMat of your incoming clip (the one below your white circle comp) to Luma.
    Now when you play through the transition should basically happen.
    Add the Stroke only composition directly above the circle comp and copy the CC Repitile effect to it.
    You should have in layer order:
    Circle composition
    Incoming clip (with its track matte set to Luma)
    Outgoing clip
    Let me know if anything is unclear.
