Activity Forums Adobe After Effects transition effect
  • transition effect
    Posted by Zach Blumstein on November 5, 2007 at 4:43 am
    i want to create a transition from one image to another
    using a black and white checkerboard but i dont want to do a linear wipe i want the squares to appear one by one kind of like a block dissolve but not randomly in a certain direction, any help would be appreciated.
    thanks
    Andrea Stewart replied 18 years, 10 months ago 3 Members · 2 Replies
  • Eric Steinberg
    November 5, 2007 at 7:07 am
    Have you tried the “Card Wipe” effect? If I interpret correctly what you’re going for, it sounds like it would be perfect.
    Kind regards,
    Eric
  • Andrea Stewart
    November 5, 2007 at 3:39 pm
    You can probably find a gradient wipe in Pixelan spices that suits your purpose. Or I’m sure you can find a whole slew of gradient wipes elsewhere on the web if you do a search.
    Basically, a gradient wipe will replace one layer with another layer using the gradient as a guide to what to replace first. Whatever’s black will go first, graduating until the whitest section is replaced.
    For better instructions, check “gradient wipe” in the manual or help menu.
    Andrea Stewart
    Producer/Editor/Director – Owner
    Germane Creative LLC
