Activity Forums Adobe Premiere Pro Transition Alignment Question
  • Transition Alignment Question
    Posted by Dave Friend on May 27, 2005 at 7:09 pm
    Is there any way to set the alignment of a transition so that it always applies the same? IOW, can a cross dissolve be set to always “Start at Cut” instead of what appears to be the default “Center at Cut”?
    Dave
    Steven L. gotz replied 21 years, 4 months ago 2 Members · 3 Replies
  • Steven L. gotz
    May 28, 2005 at 2:37 am
    Not that I know. I put in a feature request for that since I almost always begin at cut. I suggest that you put in a feature request as well.
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Dave Friend
    May 28, 2005 at 10:58 am
    [Steven L. Gotz] “I suggest that you put in a feature request as well.”
    Thank Steven. I will make the suggestion. Can you direct me to the best place to do so?
    Dave
  • Steven L. gotz
    May 28, 2005 at 2:53 pm
    Feature requests can be submitted here:
    https://www.adobe.com/support/feature.html
    Steven
