Activity Forums Adobe After Effects Transforming Mask over time
  • Transforming Mask over time
    Posted by Dasha Legge on April 9, 2009 at 9:02 am
    This is probably a silly easy question.. BUT I quite often make a mask, keyframe it and then find that I need to shift the whole thing over, across all the keyframes or resize it, but without touching the layer. I’ve tried various things but none seem to do it and have then had to either do it by hand or start again…
    There must be a way to do it… mustn’t there???
    Thanks, Dasha.
    Cornelius Henke replied 17 years, 5 months ago 2 Members · 1 Reply
  • Cornelius Henke
    April 9, 2009 at 1:57 pm
    Sometimes you have to change the mask by hand, if you go a few frames ahead or even a few seconds and change your mask at that point, over time the mask will move.
    You may also want to watch this: https://www.vimeo.com/3031889
    Lloyd Alvarez demonstrates two scripts that might interested you. Go about 14mins into it.
    Or you can google, Tracker2Mask & KeyTweak
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
