Activity Forums Adobe After Effects Transformation of Moving object
  • Transformation of Moving object
    Posted by Ryankelly on September 13, 2007 at 4:01 pm
    What I’m trying to do is take footage of a soccer ball being kicked, freezing the footage when the ball is in the air, have the soccer ball change into a football, then change the background from a soccer field into a football field. Im not sure if what im asking makes sense, but if it does, i could use some help. reply with any and all ideas…..
    thanks
    Steve Roberts replied 18 years, 11 months ago 3 Members · 3 Replies
  • Steve Roberts
    September 13, 2007 at 5:26 pm
    This is a special effects shot that needs to be planned. Along Dave’s lines:
    Do you have the shots? If so, the shots will dictate how you solve the problem, if it can be solved at all.
    If not, then how do you picture the shots in your mind? Panned with the ball? Wide shots? Can your cameraman keep up with the ball? How many takes do you want to do? Will the ball be sharp or blurry? Large or small? If large, can your cameraman follow a ball at that magnification?
    What will be in the shot at the point of soccer-to-football transfer? Sky? Buildings? Field? Will both balls be in the same location in the frame? If not, how will you account for the difference? Slide the shot? Watch the edges.
    Are you imagining a camera following the kicker, craning up to follow the ball, showing the change in the sky, then craning down to find the receiver? This can only be done with all CG (3D) or two crane $hot$, CG, and a budget for a lot of takes.
    Be aware of what you’re imagining. Sketch it out. Storyboard it.
  • Darby Edelen
    September 13, 2007 at 5:35 pm
    [Steve Roberts] “This is a special effects shot that needs to be planned.”
    Frankly, I would just be cheap about the whole thing and cut from a soccer ball flying through air to a football receiver catching a football. The audience will insert the ‘special’ effects in their head =)
    Have you seen the recent Nike commercial featuring a loosely connected montage of a football player running ‘through’ various plays on varied days in a range of weather? The cuts in that are fairly easy to see if you’re looking for them, even though they try to obscure them… It works though, because nobody wants to see those cuts. The idea gets across crystal clear, and that’s what’s important.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Steve Roberts
    September 13, 2007 at 5:41 pm
    Ah. Yes. Well said, Darby. 🙂
