Activity Forums Adobe Premiere Pro Transform effect problem premiere
  • Transform effect problem premiere
    Posted by Sebastian Forssman on May 22, 2017 at 12:44 pm
    Hello!
    I have a problem with The transform effect.
    To start with i worked well. I apllied it to several clips where i wanted to use it.
    I unchecked The “use composition shutter angle” and set my own to like 180.
    Here is where The zoom transition stopped working. If i check the composition angle marker it starts to work but then i dont have any motion blur.. This problem has accured many times. Its really annoying because i cant find any solution to it.
    Mark Grance replied 2 years, 4 months ago 5 Members · 7 Replies
  • 7 Replies
  • Sebastian Forssman
    May 22, 2017 at 4:48 pm
    No, this is actually in Premiere pro Cc 2017.
    This problem has been around since i started to use it in premiere pro cs6.
    The effects works fine in The beginning of The editing, but after a while i stops working. I then have to shut The motionblur off, then it works again. But hey, we need that motion blur.
    Anyone else with this problem?
  • Dan Powers
    May 22, 2017 at 5:38 pm
    Well I hope it isnt buggy now that you have pointed out a way to get motion blur on a basic transform! Never used that plugin!
  • Daniel Waldron
    May 23, 2017 at 8:49 pm
    Works for me fine in CC 2015. I have used this effect quite often and never had a problem.
    May 25, 2017 at 6:29 pm
    Its strange. Because it works well, and then suddenly it stops working if i’ve set my own shutter speed. if i check the “use composition’s shutter angle” it works fin again. But how can i change the composition shutter angle? I cannot not fin anything about compositions in premiere pro, only sequence.
  • Chris Spellmeyer
    March 16, 2018 at 5:18 pm
    I am having the exact same issue, can’t find a workaround! V.12.0.0
    March 16, 2018 at 9:55 pm
    I found the solution! You have to nest the clip before applying the transform effect!
  • Mark Grance
    April 18, 2024 at 2:41 pm
    (I know old post) but for people saying they never see this, it only happens if the clip is a different resolution than the timeline (UHD clip in an HD timeline). Yes nesting seems to be the only workaround.
