Activity › Forums › Apple Final Cut Pro Legacy › Transferring project from FCP to Avid with no quality loss?
  • Transferring project from FCP to Avid with no quality loss?
    Posted by Edward Calabig on August 10, 2011 at 4:02 am
    Hi I was wondering if there was a way to transfer a project from FCP to Avid with no quality loss? I’m using PluralEyes with FCP and would like to transfer everything to Avid after it’s synced since I don’t have PE for Avid. Is there a way to do this with no/minimal quality loss?
    My workflow so far has been t2i h2.64 footage -> ProRes LT
    John Pale replied 15 years, 1 month ago 4 Members · 4 Replies
  • Steve Eisen
    August 10, 2011 at 4:07 am
    Automatic Duck
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Edward Calabig
    August 10, 2011 at 4:13 am
    Thanks but I guess I should have asked… is there a free way?
  • Shane Ross
    August 10, 2011 at 4:27 am
    No. The cheapest is Boris AAF. And you cannot convert FULL projects, only sequences.
    Shane
  • John Pale
    August 10, 2011 at 4:06 pm
    Sounds like you are trying to get your synced clips into your Avid (not a sequence).
    You can export each as self contained ProRes LT Quicktimes and bring into Avid via AMA.
    If you want better performance, transcode on the Avid to a DNX resolution (Avids native HD format).
    Make sure you retain a backup, as these synced clips won’t exist anywhere else.
