Activity › Forums › Adobe Premiere Pro › Transferring Part of Clip to After Effects
  • Transferring Part of Clip to After Effects
    Posted by Kevin Van on September 14, 2009 at 6:30 pm
    Ok I used the razor tool to cut my clips into parts but now I want to just transfer one clip into After Effects. How do I do that because I’m going to do this multiple times?
    Kevin Van replied 17 years ago 2 Members · 2 Replies
  • Vince Becquiot
    September 14, 2009 at 8:10 pm
    Copy and paste. Note that you can only paste Premiere timeline clips inside an After Effects composition (not the project panel), or paste Premiere project panel clips inside the After Effects project panel.
    So make sure you first create a composition that matches resolution and frame rate, as well as equal or better length.
    Or you can import the entire timeline using the import Premiere project function in After Effects.
    I would recommend rendering to uncompressed out of After Effects if you need to bring the clips back to Premiere, or this will impose some heavy processing on your system.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Kevin Van
    September 15, 2009 at 6:33 am
    Sorry I’m new to this program but how do I go about with your recommendation? I don’t quite understand.
    Thanks for assisting me 🙂
