Transferring Meta-Data Columns on Premiere CS6.. from computer to computer.
Hello, I am working on a project that involves me logging a bunch of media in Prelude and sending it over to Premiere. Because I wanted the data to be searchable, I created Meta-Data Schema “SB Logging” and then the columns in that said schema.
When I send it over to Premiere it works fine, everything shows up, nothing is missing. However when transferring to using Premiere on a different computer, I can’t seem to get the meta-data to come up at all. This is where I need help.
The project is workable on our servers that are connected so that all the computers in the system can access each other’s HD’s directly so I’m not sure why the project can’t just open up identically…
Here are the things that I have tried that haven’t seemed to work:
-Opening the same Premiere file on the other computer (the meta-data schema doesn’t show up)
-Transferring over the Meta-Data Schema to the other computer (meta-data doesn’t show up on clips)
-Re-creating an identical meta-data schema on the other computer (meta-data doesn’t show up on clips)
-Opening Prelude file on other computer and then sending to premiere (schema doesn’t show up again…)I can’t seem to find the answer on the internet, anyone know how I can get past this?
Matt
