Activity Forums Blackmagic Design Transferring HyperDeck MXF to Avid MC
  • Transferring HyperDeck MXF to Avid MC
    Posted by Mark Crenshaw on May 17, 2012 at 8:11 pm
    We’ve just purchased a Sony PMW-350 and Black Magic HyperDeck (HDS) Shuttle 2. We’re also using MC Nitris 5.0 on Win 7 64bit.
    Our plan is to use the HDS to do the bulk of our recording thru SDI and also roll the SxS in the 350 as a backup. The latest version of the HDS software supports TC over SDI. So, we will have matching TC on the SxS and HDS clips.
    The HDS records in the following formats:
    Uncompressed .mov
    Avid DNxHD MXF
    Avid DNxHD MXF in a .mov wrapper.
    I can import the clips from either .mov format as I do from rendered AE projects but the timecode will be lost. My question is how do I get the MXF data from the HDS into an Avid bin and maintain it’s TC data? I thought about placing the MXF files in a media folder but there are no master clips to associate the media with in a project. I don’t expect there will be a file structure on the HDS to allow Avid AMA import.
    Any other avenues to check out?
    Mark Crenshaw replied 14 years, 4 months ago 2 Members · 2 Replies
  • Andreas Wojtaschek
    May 18, 2012 at 7:31 am
    Hi Marc,
    as you described just drag the files into the Avid media folder. Then you can import the clips by dragging them into a bin inside Avid or by using the Avid media tool (It should be somewhere in the upper menus).
    Regards
    Andreas
    Entertainment Producer IHK
    mindandvision
  • Mark Crenshaw
    May 18, 2012 at 12:03 pm
    Thanks Andreas.
    That’s what I ended up doing. I’ve also figured out that I can create the Avid Media folder structure on the HyperDeck’s SSD and the Avid should scan it like any other media drive…haven’t tried this yet.
    Have a great day…
