Activity Forums Apple Final Cut Pro Legacy Transferring and sync problem…HELP!!
  • Transferring and sync problem…HELP!!
    Posted by Sam Lesante jr. on November 21, 2008 at 2:04 am
    I shot about 40 min worth of footage using an hpx500 at 720p at 30fps
    I am using the Panasonic AJ-PCD20 P2 card reader to transfer to my FCP
    When i review it in the tranfer window the audio is synced, when I transfer and view, the audio is not synced and it seems to get worse as the clip plays.
    What the heck should i do???
    I also noticed that when playing back the video on my timeline (set at NTSC DV) it plays back a little “jaggedy”. Is that just because it’s on an ntsc dv timeline playing out to an sd monitor?
    TIA
    Sam
    Sam Lesante jr. replied 17 years, 9 months ago 2 Members · 2 Replies
  • Shane Ross
    November 21, 2008 at 2:28 am
    [Sam Lesante Jr.] “What the heck should i do???”
    DO you have Perian installed? That sometimes interferes.
    [Sam Lesante Jr.] “I also noticed that when playing back the video on my timeline (set at NTSC DV) it plays back a little “jaggedy”. Is that just because it’s on an ntsc dv timeline playing out to an sd monitor?”
    If you shot 720p30…DVCPRO HD…why are you editing on a DV timeline? Yeah, it will look jaggedy…you have now made your nice HD into DV. Don’t do that. You need to be editing on a DVCPRO HD 720p30 timeline.
    THAT also might be why your sync is off.
    Shane
  • Sam Lesante jr.
    November 21, 2008 at 2:43 am
    I do have perian installed. I will check that.
    after searching through some old posts i am going to see if the advanced pulldown option under preferences in the log and transfer window is checked or not. That may be the culprit.
    I threw it on a timeline quick just to view it – i will view it on 720p30 timeline next time. I don’t have to edit it, i was just hired to shoot it and send the footage on a hard drive to the another post house.
    thanks for the quick response.
    sam
