transfering from PS to Illustrator woes!!!!
First off, I’m a complete Illustrator noob.
So I have a graphic I created in Photoshop that I need to send to another company as an Illustrator file.
So, I open the doc in Illustrator and it then informs me that it’s converting photoshop layers to objects. It then opens up fine and all seems to be well.
I then chose to save it as an .EPS doc.
I get a message that says, “When spot colors are used with transparency, changing them to process colors outside Illustrator can generate unexpected results.”
I just click, “continue”.
I have to go through one last dialogue box before saving. I don’t mess with any of the controls in there.
After saving, it seems to open back up fine in Illustrator.
However, every time the graphic designer at the other company tries to open it up, he says that the file is corrupted.
Any ideas? I am clueless here!
“The secret to creativity is knowing how to hide your sources.” –Albert Einstein
