Activity Forums Panasonic Cameras Transfering from HVX200 8 GB p2 card into FCP 6.0.4
  • Transfering from HVX200 8 GB p2 card into FCP 6.0.4
    Posted by Nate Cranney on October 2, 2008 at 5:45 pm
    I am having trouble transferring clips from a AG-HVX200P with a 8 GB p2 card into FCP 6.0.4. It starts the transfer and then right before it finishes it stops and gives me an unknown error. I thought it might possibly an anti-virus program that I had running but I threw that away and it still does not work. I would appreciate any help I could get thanks! BTW I am using a Mac 10.4.11
    Cal Gordon replied 17 years, 9 months ago 5 Members · 13 Replies
  • 13 Replies
  • Jeremy Garchow
    October 2, 2008 at 8:30 pm
    Drag the CONTENTS and lastclip.txt items into a Folder on your hard drive, then do the log and transfer form that folder, not form the card itself.
    Jeremy
  • Nate Cranney
    October 2, 2008 at 9:51 pm
    I have tried that, however it just gives me the exact same problem. Any other suggestions?
  • Shane Ross
    October 2, 2008 at 9:55 pm
    #36 – One or More P2 files failed to import.
    Shane’s Stock Answer #36 – “One or more clips failed to import…”
    Very often in the field with this camera the camera operator will delete clips from the P2 card that they just don’t like. That is the beauty of this camera. But, the still for that video file (located in the CLIP folder in the CONTENTS folder)…the still that you see when you are in the P2 Import window…is not deleted. So you will see the image, and the name, but the video file would have been deleted.
    What you can do it compare the file names in the VIDEO folder and CLIP folder and see if anything is missing. If something is, then you know what the problem is. You can then just import the rest a few at time, skipping that one.
    ALSO…in the P2 Import window…in the P2 Browser, there is a little sprocket drop down menu. Click on that and choose PREFERENCES. Uncheck REMOVE PULLDOWN and then try importing again.
    ALSO…make sure your file names aren’t too long. Try shortening them and see if that works.
    Shane
  • Nate Cranney
    October 2, 2008 at 10:09 pm
    Thanks for the tip. I shot something on the same camera myself to see if it was something like that however I came up with the same problem. I also tried adjusting the preferences also to no avail. Any other suggestions?
  • Shane Ross
    October 2, 2008 at 10:14 pm
    What version of QT are you running?
    Shane
  • Nate Cranney
    October 2, 2008 at 10:23 pm
    QT 7.5.5
  • Shane Ross
    October 2, 2008 at 10:51 pm
    I have heard of issues with people importing with this version of the software. Cropping up more and more.
    Shane
  • Nate Cranney
    October 2, 2008 at 10:53 pm
    Thanks. I hadn’t heard about problems before. I’ll try and downgrade and see if that fixes the problem. Thanks again.
  • Nate Cranney
    October 3, 2008 at 7:30 pm
    I tried to downgrade my quicktime to 7.4.5 but I still have the same problem. Any other ideas?
  • Tom Klein
    October 5, 2008 at 11:49 am
    Hi Nate,
    I’ve had simmilar issues since QT 7.5.5 and OS 10.5.5. may i suggest you do as i did and run the info from the card and capture it in real time, that’s if your camera will play it, I suspect your issue is same as mine.
    One of my 32gig P2 cards is now not recognized and just “Hangs” the macpro when trying to drag n drop or log n transfer.
    The card will need to be formated and all should be good (fingers crossed). My issue is intermittent, the first card gave problems, the other four from a shoot were OK ? , I re booted up on an earlier spare OS and QT and it was same with that 32gig P2 card, other cards were all good, Go figure ??.
    get your info “saved to a drive” prior to doing any testing.
    Cheers
    Tom K
