Activity Forums VEGAS Pro transfering footage to computer
  • transfering footage to computer
    Posted by Sean Holligan on May 1, 2012 at 12:50 am
    I have a panasonic HMC40 and sony movie studio HD. I have been trying to transfer footage to computer using the Micro SD and also the fire wire but I can’t transfer it. The footage is still on the card. I need help thanks.
    Matt Crowley replied 14 years, 4 months ago 3 Members · 2 Replies
  • Stephen Crye
    May 1, 2012 at 3:28 am
    Have you tried asking the nice Panny People in this forum? Once the files are in the computer Vegas will be able to read them.
    https://forums.creativecow.net/panasonicagdvx100
    Steve
    Win7 Pro X64 on Dell T3400, MultiTB SATA, 8GB RAM, nVidia FX 570, Vegas 10e (and 11) x64 DVDA 5.2(build 133) Sony HDR-CX550V
  • Matt Crowley
    May 1, 2012 at 12:14 pm
    First, make sure that your computer detects your camera when you connect it – you may need to install a driver. You should also be able to see the camera as a removable disk drive in Windows Explorer.
    If you have Movie Studio Platinum, you can try using its built-in Device Explorer (on the View menu) to import camera footage directly from the camera over its USB port. It should automatically detect the camera and give you a list of clips to import.
    The other option is using Panasonic’s software to do the import. You should have received a software disk with the camera. I don’t know what the prosumer/pro cameras come with, but consumer Panasonic cameras come with something called HD Writer which doubles as a capture/import utility and basic editor/converter. It will copy the AVCHD footage from the camera and give the files sensible time-stamped names, and you can then use them directly in Vegas.
