Transfer video from the JVC GYHD 110 camera to Final Cut
Hi! I used a JVC GY HD110 for a recording in HD. I can’t transfer the footage to Final Cut. I used 3 different computer and nothing works. I changed the HD playback and nothing. The problem is the camera. But now I have another problem. I used another camera (Sony) as a playback and doesn’t work either. I can see the recording in the camera but not in the computer. 3 different computers same problem. When I changed the tape in the Sony camera everything works good. So the recording that I did with JVC and the camera is the problem. I tried to make a copy straight from the JVC camera to DVD recorder changing the HD playback mode to NTSC, 480, also in native and nothing works. How can I change the HD footage (HDV-HD720/30p that I have to standard format? I can’t use the camera JVC as a playback but I can use the Sony camera. Any advice?
