Activity Forums Adobe Premiere Pro Transfer modes?? Adding to imported jpegs and using transitions?
  • Transfer modes?? Adding to imported jpegs and using transitions?
    Posted by Jason Banker on July 8, 2006 at 11:11 pm
    I am trying to add a screen effect to an imported jpg image but it won’t let me do it?
    The image is greyscale and 1650×1104 if that makes a difference.
    I am also having problems with dissolves on video layers with transfer modes applied. The transition goes to white or black depending on what the mode is. How can I make a smooth transition?
    Any help would be great. Thanks
    Aanarav Sareen replied 20 years, 2 months ago 2 Members · 1 Reply
  • Aanarav Sareen
    July 10, 2006 at 5:52 am
    What version of Premiere Pro are you using? Also, can you post a sample clip, so that we can try to re-produce the issues you are seeing? Also, try to reduce the dimensions of the image to see if that helps.
    Aanarav Sareen
    premiere@asvideoproductions.com
