Activity › Forums › Adobe After Effects › Transfer from Mac to PC
  • Transfer from Mac to PC
    Posted by Clintw80 on September 25, 2007 at 12:49 am
    I’m trying to export a full screen 3 minute QT from an old version of Final Cut Pro on to AE for PC. I’ve tried exporting QT’s in Sorenson and a few other codecs, but everytime I put it on the PC, it says it isn’t a valid QT file, and that AE can’t open it. Am I using the wrong codec? Is it a Mac/PC issue? Is the file too big?
    Steve Roberts replied 19 years ago 4 Members · 5 Replies
  • Jeff Mcbride
    September 25, 2007 at 1:33 pm
    Are you making the file self-contained? Do so if not.
    Jeff McBride
    Motion Graphic Designer/Editor
    LimeGreen
    Chicago, IL
    http://www.limegreenproductions.com
  • Steve Roberts
    September 25, 2007 at 1:35 pm
    If your Windows drive is formatted to FAT32, you have a 4GB files size limit on that drive.
    If the drive is NTFS, Mac can’t write to it.
    Solution? Figure out how much of the file needs to be exported to keep it under 4GB, and export segments of that length or smaller. Reassemble in AE.
    But that may not be the problem. Did you try rendering to the Animation codec? You should use a high-quality codec, not something like Sorenson.
    Is the filename under 30 characters?
    Does it have a MOV extension?
  • Steve Roberts
    September 25, 2007 at 1:37 pm
    Good answer! Didn’t think of that!
  • Darby Edelen
    September 25, 2007 at 4:19 pm
    [Steve Roberts] “If the drive is NTFS, Mac can’t write to it.”
    They can over a network… go figure.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Steve Roberts
    September 25, 2007 at 5:16 pm
    Hm. Food for thought.
