Activity › Forums › Adobe Premiere Pro › Transfer footage from a Sony HDR-FX1 camera
  • Jeff Pulera
    March 27, 2012 at 2:42 pm
    Hi Rafa,
    HDV camcorders all have an option in the menu system for downconverting HD playback to SD, both on 1394 (i.Link convert) and analog outputs. You should find a setting that says “1080i/480i” – switch this to “1080i” to get the HD output
    Jeff Pulera
    Safe Harbor Computers
  • Rafael Otero
    March 27, 2012 at 3:00 pm
    jeff,
    Thank you for replying so quickly. I found the menu you mentioned, but the only options it allows are “480i” and “1080i/480i”. I already had set for the second option… no option for ONLY 1080i.
    Rafa.
  • Ann Bens
    March 27, 2012 at 8:14 pm
    Did you turn i-Link-CONV off?
    Othewise it will downsample.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Rafael Otero
    April 2, 2012 at 1:13 pm
    Hi Ann,
    Turning i-Link-CONV off did the trick.
    THANKS!
    Rafa.
  • Steve Robinson
    August 8, 2014 at 6:32 am
    I am having the same issue with my sony fx1’s being 720 x480.I have tried different combinations with the menu settings.I tried on both my cameras.I even tried throwing in a new tape ( just incase the recorded tape is not allowing the camera to change because it might detect the tape was recorded at 720 ). I have noticed the menu saying to unplug i-link cable.Changes not allowed. I tried this while i had firewire in and when it wasn’t. I find it odd to be a bad camera because i have 2 of the same (HDRFX1). Im trying these menu settings while unit is in vtr mode. I even took a look at the menu that had to do with recording settings to see if anything there made any sense. Any help would be appreciated.
