Activity Forums Adobe Premiere Pro Transcript changes
  • Transcript changes
    Posted by Alan Glait on February 27, 2024 at 1:06 am
    Hi !
    I did a transcript. Then edited the captions and as I changed the font, some captions are in 3 or more lines. is there a way to re order the captions in 2 lines ?
    Thanks in advance
    Tod Hopkins replied 2 years, 6 months ago 3 Members · 2 Replies
    February 27, 2024 at 3:12 am
    Hey Alan,
    I normally make changes manually inside the subtitle text tool box, or on-screen, in the line itself.
    But then most of my subtitling are from translated interviews delivered in a word document.
    However, this might help you:
    Point 3 on the Adobe support page:
    Change text position.
    Use the Align and Transform options to align your text and change its position.
    • Position captions with zones: You can choose from different zones to position your caption in different areas on screen.
    • Fine tune position: Through Set Horizontal and Set Vertical Position you can add an offset to your zone setting.
      Vertical and horizontal text alignment are automatically set according to the zone position as well.
    • Change the text box size: If you want to shrink
      or expand the text box size you can do this through Set Horizontal Scale
      and Set Vertical Scale. This will affect text wrapping and
      paragraph align settings. You can also change the text. box size using
      the text box controls on the Program Monitor.
    https://helpx.adobe.com/uk/premiere-pro/using/working-with-captions.html
    If you do it in the essential graphics panel you can save your set-up (track-style) and apply it to all captions on the captions track.
  • Tod Hopkins
    February 27, 2024 at 2:29 pm
    Or reduce font size and/or tracking.
