Activity Forums Adobe Premiere Pro Transcribe using prompter script
  • Transcribe using prompter script
    Posted by Joe Bloemer on October 25, 2023 at 10:40 pm
    Odd question. I don’t often do captioning.
    I’d like to capion a sequence to use as an open caption. There are many technical terms/phrases/spellings that will need to be manually corrected. Very time consuming.
    I have a clean prompter script. In the past I’ve used software that would use a text script to more accurately build a caption. I don’t see that function in premiere. Does anyone know if that exists? It seems like an extremely basic need and has been around a log time.
    Thanks for any direction.
    Hector Vera replied 2 years, 10 months ago 2 Members · 1 Reply
  • Hector Vera
    October 27, 2023 at 12:37 am
    Not sure if this is the exact thing you are looking for involving captions in Premiere Pro but there are at least ways around this. Perhaps this video will help: https://youtu.be/A0BldihvoBo?si=TECkCyzbarjiW10R
    I know that I can edit text in Adobe Premiere Pro and add more in the timeline since I have several experiences to do them normally.
