Activity Forums Adobe Encore DVD Transcoding in Encore
  • Transcoding in Encore
    Posted by Bob Mane on January 22, 2012 at 8:03 pm
    im using vegas and need to set – flexible – chapter points in encore, so my understanding is i have to render a non-compliant file and use “Transcoding in Encore” in order to set those chapter markers where i want.
    is there some format that would be best for this?
    i am hoping i can come up with a workflow that lets me
    1. render once from vegas
    2. set chapter markers in encore
    3. transcode / build in encore in for flash – dvd – bluray.
    avi? h264? mpeg?
    Bob Mane replied 14 years, 7 months ago 2 Members · 2 Replies
  • Jeff Pulera
    January 23, 2012 at 2:26 pm
    Hi Bob,
    From Vegas, Export to the “H.264 for Blu-ray” format, should result in .m4v and .wav audio files that you can then Import into Encore. Add your chapter markers, and create menus. Burn the Blu-ray disc.
    Encore will allow you to switch the project format – just change to DVD and you can use the same project with chapters/menus intact. The Blu-ray files will be transcoded to DVD.
    I’ve not done a Flash output, but you ought to be able to do that as well from the same original Blu-ray project. Maybe you want to use “Save as” from the Blu-ray job to create copies to work with for DVD and Flash output.
    Jeff Pulera
    Safe Harbor Computers
  • Bob Mane
    January 23, 2012 at 3:18 pm
    “H.264 for Blu-ray”
    what is that under? avi, main concept??
