Activity › Forums › Apple Final Cut Pro Legacy › Transcoding from 23.98 to 29.97???
  • Transcoding from 23.98 to 29.97???
    Posted by Christopher Young on March 20, 2012 at 10:05 pm
    I am working in Final Cut Pro 7 with compressor.
    I am transcoding from 23.98 to 29.97.
    I understand that the transcode will add duplicate frames every 5-6 frames to compensate.
    My question is this: Is there a better way to change the frame rate because right now the video is less than ideal. I’m wondering if there
    is a setting in compressor ( which is what was used ) to make the duplicate frames not occur on transcode or if another software or editing platform does this compression better.
    What is the proper way to eliminate these duplicate frames to achieve a smooth looking video.
    Any help in this regard would be awesome.
    Christopher Young replied 14 years, 6 months ago 2 Members · 2 Replies
  • Jerry Wise
    March 20, 2012 at 10:29 pm
    there is “droplet” you can use in Compressor to add pulldown to your 23.98 footage. it works great. search the forum for the droplet.
  • Christopher Young
    March 20, 2012 at 11:24 pm
    thank you very much. apparently there is an interlaced option that works very well.
