Activity Forums Apple Final Cut Pro Legacy Transcoding avi to mpeg2 using Compressor
  • Transcoding avi to mpeg2 using Compressor
    Posted by Lanzi on March 11, 2006 at 11:49 am
    I am in the process of reading the Compressor User Manual after I tried to quickly use Compressor 1.0 without the guide. But I had a problem.So as I read the manual I ask the fpllowing question.
    I am trying to burn an avi file (75 minutes) onto DVD with toast. The encoding takes really long. I decided to use Compressor for the first time. The first thing I noticed without proceeding to the encoding step is that once the avi file is dropped in Compressor and I press preview, there is no audio. I get audio with mpeg or mov files.
    Is it a question of Compressor settings or do I have to convert the avi file into say mpeg or mov before encoding with Compressor? The avi file came on a DVD as data and is not from one of my FCP projects.
    Thanks.
    David Roth weiss replied 20 years, 6 months ago 2 Members · 1 Reply
  • David Roth weiss
    March 11, 2006 at 4:10 pm
    There are many types of AVIs, and its not always possible to kmow what codecs were used to create them. Depending on the power of your MAC, a 75-min encode and burn using Toast may take a few hours, but so too will encoding with Compressor. Rather than trying to learn Compressor, you’re probably better off just going with Toast and hoping for the best.
