Activity Forums Apple Final Cut Pro Legacy tranfer final cut file 16:9 DVProHD into 4:3 miniDV
  • tranfer final cut file 16:9 DVProHD into 4:3 miniDV
    Posted by Yuliya Lanina on September 9, 2008 at 3:46 am
    I have a film that is in 16:9 DVProHD format and I need to have it transfered to MiniDV 4:3 for the festival. The file is in 6.02 version of Final Cut. The lab with miniDV deck that I can have access to only runs version 5.1.4 of Final Cut. Can anyone suggest of the best way to go about it?
    Thank you,
    Yuliya
    Yuliya Lanina replied 17 years, 12 months ago 4 Members · 10 Replies
  • 10 Replies
  • David Roth weiss
    September 9, 2008 at 3:59 am
    Export a 4×3 SD DV file directly from your timeline using Compressor or Quicktime Conversion and bring that to the other facility on a firewire drive.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Yuliya Lanina
    September 9, 2008 at 4:27 am
    What would be the exact settings and size in Quicktime conversion? I do not see the exact option you mentioned. Thank you.
  • Steve Eisen
    September 9, 2008 at 4:57 am
    DV-NTSC or DV-PAL
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Yuliya Lanina
    September 9, 2008 at 12:24 pm
    I tried to export it with settings DV/DVC Pro NTSC with size 720×480 NTSC 4:3 with checked preserve aspect ratio and the film came out squished with not so good resolution. What may I be doing wrong?
  • Alex Elkins
    September 9, 2008 at 1:26 pm
    [yuliya lanina] “with checked preserve aspect ratio and the film came out squished with not so good resolution.”
    To stop it from squishing you need to NOT preserve the aspect ratio. However, this means that you will end up with the edges of your film cropped, which probably isn’t what you want.
    Personally I would open a new sequence in FCP, but change your settings to DV – use the Easy Setup option to do this if you’re unsure. Then just copy and paste your original sequence into it and you should be left with a 4×3 film with black bars at the top and bottom, keeping it widescreen but as a 4×3 video. Then go to File>Export>Quicktime Movie and wack it onto your firewire drive.
  • Yuliya Lanina
    September 9, 2008 at 4:32 pm
    Thank you! The last suggestion seem to work. How would I now export it to MiniDV?
  • Alex Elkins
    September 9, 2008 at 5:22 pm
    You mentioned in your first post that you’re taking it to a lab to be transferred to Mini DV, so you just need to put your video file onto an external harddrive or even a DVD if it’s not too long, then give that to the lab. They’ll be able to sort the rest out.
  • Yuliya Lanina
    September 9, 2008 at 6:30 pm
    oh, I meant that the lab I have access to has MiniDV deck but I am the one to do this. So I would need to know how to transfer quicktime file to MiniDv. Thank you so much for your help.
  • Steve Eisen
    September 9, 2008 at 8:59 pm
    Connect the Mini DV Deck/camera to your computer with FCP and use the print to tape option. If you need a step by step, the manual (under FCP Help) will give it to you.
    Steve Eisen
    Board of Directors
  • Yuliya Lanina
    September 12, 2008 at 11:05 am
    Thank you for all your help! I seem to get the file in proper format and working but when I transfered it to MiniDV the sound did not record. What may I be doing wrong? Yuliya
