Activity › Forums › Apple Motion › Trailing stars
Trailing stars
Posted by Michael Campione on August 26, 2014 at 10:47 pmHi All,
Is there a way to duplicate the Paramont stars movement in Motion 5? Or if you could steer me to a good tutorial. Having a heck of a time with it. I’ve seen a couple of tutorials in after effects so there must be something in Motion.
Thanks much.
Michael
Michael Campione replied 12 years ago 2 Members · 12 Replies -
Mark Spencer
August 26, 2014 at 11:02 pmI’d use a replicator and animate the stars along a motion path in 3D.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
https://www.applemotion.net -
Michael Campione
August 27, 2014 at 1:11 amThanks Mark
Sad to say I haven’t spent much time with the replicators. Doing simple stuff but need to jump to the next level.
It makes sense what your saying especially since I’m trying to do it by building each star and each with its own B-Spline. I don’t see it ending well. lol
Do I use like the Line Segment replicator and modify it? There doesn’t seem to be a generic one anywhere.or I’m not looking hard enough.
Michael
Michael Campione
August 27, 2014 at 1:43 amAh! I think I figured it out.
Didn’t see the little replicator button way down in the bottom corner. -
Mark Spencer
August 27, 2014 at 1:44 amThere are existing star shapes in the Library you can use. You replicate them to Geometry and put the motion path in the well. Doing just the semi-circle is relatively easy. If you want to fly them in from the foreground, twisting through 3D space, that takes some more effort and knowledge.
Mark Spencer
Michael Campione
August 27, 2014 at 2:58 amMark I really appreciate you getting me this far.
So here’s where I am.
I did use the star shape.Replicator:
set to Geometry
Shape source well is empty
Points set to 15 (stars)
They’re piled on top of each other.Motion path:
Path Shape is set to open spline (because that seems to be the only thing I can shape the path with)
Shape Type B-SplineProblem: Stars are stacked on top of one another and cannot drag Motion Path to Replicator well.
Stars follow path as a clump and can’t seem to separate themOddly enough the 3D space and drawing the B-Spline path I don’t seem to be having any trouble with making one star perform the way I want. Its getting the 15 to follow after one another.
Michael
Michael Campione
August 27, 2014 at 9:51 pmI almost have this nailed.
In addition to my last post, I added a sequential replicator (something I had to really search for)
That gave me the trailing stars. However,
The stars build out to 15 then end as one star at the end of the motion path.
Heres how far I got and the problem.
https://youtu.be/tbH91nYMCYIIs there a way to control the parameter of each individual star? i.e. Each yellow stars need to stop on their respective black stars and not back into one star (object). In addition each has to rotate slightly into position.
If this is something I have to do by individually attach a motion path to each star then so be it. Just thought there might be a better way.
Again thanks for any help
Mark Spencer
August 27, 2014 at 10:47 pmI’m not sure the sequence replicator is going to get you there.
The best way to approach this is going to be to use a text layer instead of a shape or graphic. By using Edit > Special Characters you can insert a star symbol and then copy-paste it.
The advantage of a text layer is that you can set the Type (in the Layout pane), then set the Path to Geometry, then you can keyframe the Offset parameter to animate the series of characters (stars) along this Motion path, and they keep their relative positions.
Mark Spencer
Michael Campione
August 28, 2014 at 9:25 pmHi Mark
I am going to try the text layer when I have the time to mess with it. At the moment I’m a bit under the gun and it’s taken way too long to get to this point.
As it stands I built this using the star shape since I already had each star sized and positioned before coming on the forum.So here’s how I did it from a novice perspective.
I cut and pasted the each previous motion path to the next star then positioned it using the control points.
I figured now I can apply the 3D to each star individually to get the same effect as Paramont as indicated with the first star that comes into frame. It won’t be a simple cut and paste of the keyframes like I can with the scale but it will get there.
I figured the way the stars align (no pun) I had to treat them independently.
It didn’t take as long as I thought but no doubt an unorthodox way of doing it.Am I on the right track here?
Thanks for helping me get this far.
Michael
Mark Spencer
August 28, 2014 at 9:46 pmNot bad! I do think you’d find it easier with text on a path.
Mark Spencer
Michael Campione
August 29, 2014 at 8:47 pmI will most certainly give it a try when I have more time to play. 🙂
Thanks again.
