Activity Forums Apple Final Cut Pro Legacy TRACKS 1&2 TO CHANNELS 3&4
  • TRACKS 1&2 TO CHANNELS 3&4
    Posted by Paul Factora on January 20, 2007 at 9:05 pm
    Not sure why it’s not working.
    I’ve assigned Tracks 1 & 2 on my timeline to output to 3&4 via the rightclick setting on the grey area of the lock icon, but…..
    In the Tool Bench, when I play my sequence it still comes out on channels 1&2.
    When I scrub the timeline Channels 3&4 Show levels.
    what am I misisng here???
    thanks,
    -p
    Paul Factora replied 19 years, 8 months ago 4 Members · 6 Replies
  • John Pale
    January 20, 2007 at 9:21 pm
    Are your Audio Output settings in your Sequence Settings set to Stereo (default) or 4 channel?
  • Paul Factora
    January 20, 2007 at 9:47 pm
    they are set to 4 channel
  • Paul Factora
    January 20, 2007 at 9:51 pm
    Whats strange is when I click the Downmix Button on the audio mixer, the levels will come out on 3&4 and will also show up on 3&4 on the mixer.
    But when I go to Insert Edit, NO levels come out. Not even the Bartone, even though I was able to preview both bartone and sequence levels.
  • Dan Riley
    January 21, 2007 at 2:06 am
    do you have four little lights on the front of the edit to tape window
    to show all four audio channels enabled?
    If you go to audio/video settings, AV devices, is there a check in the box
    “different output for edit to tape/print to video? If so, uncheck it.
    Dan
  • Martin Baker
    January 21, 2007 at 7:37 am
    From the scrubbing issue it sounds like it could be weirdness with audio renders.
    – Select all the Audio (ONLY!) clips
    – Press Ctrl-B (to disable the clips and break link to render files)
    – Press Ctrl-B again (to enable the clips)
    – Now try it
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    NEW! Final Print for FCP
    Hot Tips video podcast
  • Paul Factora
    January 22, 2007 at 12:19 am
    “If you go to audio/video settings, AV devices, is there a check in the box
    “different output for edit to tape/print to video? If so, uncheck it.”
    THANKS DAN!!!!
