Activity › Forums › Adobe After Effects › Tracking trouble
  • Tracking trouble
    Posted by Jeremy Garchow on January 13, 2015 at 5:04 pm
    I need to track this shot. It’s difficult, and nothing is working. Eventually, I will need to replace a screen or three.
    Ae Corner Pin tacking falls apart instantly, Mocha, while I am no expert, falls apart too.
    I may end up just placing it by hand. What’s the best way to distort the incoming screen replacement to recreate the fisheye bend?
    Track me
    Cheers,
    Jeremy
    Jeremy Garchow replied 11 years, 8 months ago 2 Members · 2 Replies
  • Walter Soyka
    January 13, 2015 at 6:56 pm
    [Jeremy Garchow] “What’s the best way to distort the incoming screen replacement to recreate the fisheye bend?”
    First, remove the fisheye with Optics Distortion (check “Reverse lens distortion”), then track and comp, then re-apply the fisheye with Optics Distortion (duplicate your prior Optics Disortion effect and uncheck “Reverse lens distortion.”).
    Check this out:
    https://vimeo.com/24756469
    I don’t use Mocha very often at all, but if you by chance have Mocha Pro, you can use the Lens Module.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Jeremy Garchow
    January 13, 2015 at 10:39 pm
    Thanks.
    I scrapped it. It was beyond my expertise, although I learned a lot about Mocha. It turned out it was working. It would have been an awesome shot, but I had to move on.
    Jeremy
