Tracking that ZIT
I got good help here a couple days ago with my need to erase a couple of zits from a face in an 18-second ECU soundbite. Chris Smith — If you are reading thing, your suggestions left me with one problem that I hope you or someone else can address. I am unable to get the mask that I created to track the zit. You wrote:
First open your tracker and get a good track on the zit… Apply the data to a null layer.
I opened the tracker (for the first time in my experience) then RTFM on tracking, and I was able to get a good track over time on the zit. Then I created a null object.You went on:
Create a solid. Make a small circle shaped mask in the middle of the solid (anywhere on the solid really). Now parent this solid layer to the null. Your little circle should track in sync with the zit. Now just grab the circle layer in the comp window and move it right over the zit… Now the circle should track right over the zit the whole time.
Following these instructions, I was able to get an excellent zit removal on that first frame. However, I could not get the mask to track the zit. Itg doesn’t seem to be “using” the tracking data…and I did parent the solid to the null layer. But that little colored dot just sits there. Do you have any idea what I might be doing wrong? One thought: for the mask, I just added a new mask to the solid layer and then set the mask shape to 15×15 ellipse. Is that the right way to do what you suggest? Another thought: Does the tracking data need to be erased from the main layer after it is applied to the null object?Any assistance on this new (for me) use of AE would be much appreciated.
Lee
