Activity Forums Adobe After Effects Tracking Problem Adobe After Effects
  • Tracking Problem Adobe After Effects
    Posted by Dillon Felber on March 19, 2010 at 11:03 pm
    Hi, I was testing out tracking by using a picture frame and puting a video within the frame, using tracking in after effects. The track worked well after some adjustments. After that, I applied the track to a null object so that I can parent the other video clip to the null. The clip goes with the null but 3 or 4 quick times within the track, the null flips one way and then another, so at those random spots the clip inside the frame goes upside down, or sideways etc…
    why is it doing this/any suggestions to fix it?
    THANKS!
    Dillon Felber replied 16 years, 5 months ago 3 Members · 3 Replies
  • Scott Novasic
    March 20, 2010 at 3:40 am
    is this a tracking test for you? Why not just precomp in the video inside the frame and parent whatever you need to that…..
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
  • Alperen T. ayhan
    March 20, 2010 at 2:51 pm
    I couldn’t understand the situation exactly (my Eng. is not so good)but I think the problem is caused by parenting. Try parenting position of the layers not the layers. Then, in my opinion your problem will be solved. and have you tracked your frame position or position-rotation? may be you should try just position.
    Alperen T. AYHAN
    http://www.sinamasal.com
    Always cinema…
  • Dillon Felber
    March 20, 2010 at 9:54 pm
    Yes this is a tracking test for me…How would I precomp the video inside the frame? I do the tracking and click “Edit Target” and select to use a Null, or the video- and either way, it rotates randomly but the position and scaling is correct…
    Thanks-still new to using after effects
