Activity Forums Adobe After Effects Tracking problem
  • Tracking problem
    Posted by Ben Hartley on March 3, 2012 at 2:27 pm
    I have an image which i have tracked onto a TV screen (to which I have applied corner pin values).
    However the image I have added does not look as crisp as it should do, even though the resolution of the comps are all full and the image looks perfectly crisp inside the applied comp itself.
    Any suggestions??? It must be something to do with the corner pin values??
    Thank-you
    If it looks good, look at it.
    Ben Hartley replied 14 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
