Activity Forums Adobe After Effects Tracking – Perspective corner pin
  • Tracking – Perspective corner pin
    Posted by Tal Wagner on September 20, 2018 at 11:50 am
    Hii I have a question about tracking.
    Im tracking a board (cutting matt) that lays on a table.
    The footage is 4k.
    One corners of the board is hidden along all the movie but the board has measuring lines on it so I can track a smaller area on the board without distructions and the tracking results are pretty good.
    But then when I use this tracking, the “target” comp has to be the same dimensions as the tracked area, otherwise it will stretch the target comp to fit the tracking area.
    is there a way to track the smaller but clean area and to put a larger comp so it fits all the board?
    I add a picture so u can see
    Thanks ☺
    Tal Wagner replied 7 years, 11 months ago 2 Members · 2 Replies
  • Blaise Douros
    September 20, 2018 at 6:23 pm
    Mocha works well for this–it was built to handle that kind of thing. You could also use the 3D Camera Tracker, if there’s enough camera movement–given the nice visible grid, AE should have no trouble tracking the table.
  • Tal Wagner
    September 20, 2018 at 8:49 pm
    Great, I should begin using Mocha.
    thanks a lot
