Activity Forums Adobe After Effects tracking difficulties
  • tracking difficulties
    Posted by Malcolm Desoto on August 22, 2008 at 8:30 pm
    IS there a way to access the tracking information after you’ve applied the data?
    I noticed a little jerk after I applied the tracking information. The key frames are there, but I can’t seem to adjust them.
    I could probably adjust each keyframe one by one, by entering values; but that seems a lot more tedious than being able to see the tracking path and being able to drag the track point back into place.
    thanks.
    “The secret to creativity is knowing how to hide your sources.” –Albert Einstein
    Roland R. kahlenberg replied 18 years, 1 month ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    August 24, 2008 at 12:36 am
    The layer that you tracked will have loads of information. The layer that you applied the data to will also have keyframes which are adjustable. You’re probably looking at the wrong layer if you can’t change the value of the keyframes.
    HTH
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
