Activity Forums Adobe After Effects Tracking Data to Mask
  • Tracking Data to Mask
    Posted by Jason Mckee on December 12, 2007 at 7:22 pm
    Alright again I’m sure this is simple but in the change from AE 7 to AE CS3 I’m a bit confused. What I have done is applied the tracking data from Layer 1 to a null object. I need to attach the tracking data from that null object to Layer 2’s mask position property. Basically I just need the movement of layer 2’s mask to match that of Layer 1’s tracking data. I would have normally used the pick whip and just created an expression but it seems to be different in this version. Then again maybe it’s just me. Somebody please help. Thank you.
    Jason Mckee replied 18 years, 8 months ago 2 Members · 2 Replies
  • Steve Roberts
    December 12, 2007 at 7:41 pm
    You can apply to the *layer position* property, but not to the *mask shape* property. There’s no “mask position” property.
    Search the COW for “track” and “mask”, or maybe add “vertices” to find a script that should help if you want to apply tracking data to the mask vertices.
  • Jason Mckee
    December 13, 2007 at 11:35 pm
    Thanks for that. Wasn’t sure if there was another way but it worked great none the less.
