Activity Forums Adobe After Effects Tracking data keeps moving layer’s start point!
  • Tracking data keeps moving layer’s start point!
    Posted by Sean Worsell on March 23, 2010 at 7:36 am
    I have two layers visible at the same time (both are scaled down so they are side-by-side). And I track the motion in the left-hand layer to apply it to the right-hand layer, so the right hand one moves in tandem with the imagery in the left hand one.
    But one problem I cant’ figure out–when I apply the tracking info to the right-hand layer, it immediately moves the entire layer over top of the first layer (but offset…centred on first track point maybe?) before it applies the re-positioning. Then it moves fine, in tandem with left-hand layer. But I don’t want it moved over. I want it to stay right where it is when the tracking is applied.
    Any thoughts about what I’m doing wrong / what’s happening?
    Sean Worsell replied 16 years, 6 months ago 2 Members · 2 Replies
  • Bartek Skorupa
    March 23, 2010 at 7:59 am
    First issue:
    You scaled down the layer that you used as a tracking data source. Tracking is done using the layer itself and doesn’t respect it’s scale.
    Solution:
    precompose the source layer, and track this composition
    Second issue:
    Applying the tracking data to the destination layer moves it to the position of the track. That’s how it works.
    Solution:
    Add the null layer. Apply the tracking data to this null. Parent your destination layer to this null.
    voila
    Bartek Skorupa
    Warszawa, Poland
  • Sean Worsell
    March 23, 2010 at 8:26 am
    Wow, you are darned good. That’s amazing advice! Thanks for being so quick too. Gotta love the Cow eh?
    cheers.
