Activity Forums Adobe After Effects Tracker Trouble
  • Tracker Trouble
    Posted by Kevin Lee on February 28, 2007 at 2:03 am
    I am trying to make a short clip of opening an envelope, pulling the folded paper out, and the rolling video clip being on that sheet of paper as it is unfolding. The problem I am having is the motion tracker. I cannot get the corners of the video clip to align with the two tracking points. It follows perfectly but is off to the side. Is there one small detail I am overlooking with the anchor point on the rolling video?
    Kevin Lee replied 19 years, 6 months ago 2 Members · 2 Replies
  • Peter O’connell
    February 28, 2007 at 2:49 am
    Hi you can use an instance of the cornerpin effect to nudge the corner that is off back into place. Use as few keyframes as possible.
    Good luck
    Pete O’Connell
    http://www.barxseven.com
  • Kevin Lee
    February 28, 2007 at 3:07 am
    Thanks pete, I did find out that the motion tracker point 1 controls the anchor point of the video, and fixed the big problem, but the corner pin might help with nudging in the fine tuning. Thanks for the tip.
